Hi @mhschultzz ,
Don’t know the adapter but if there are no recessed screws hidden under the labels then if the adapter case has a welded seam running around the case, try the following:
With a wide bladed tool such as a 1.5” paint scraper, (the sharper the blade the better) try placing the blade along the long edge seam and then give the handle end of the scraper a short sharp tap with a hammer to see if it cracks open along the seam.
I have an 80 % success rate opening welded cases this way without causing any external damage to the case.
You may find the the “lip” edge of the seam may crack and break off on the inside but that is covered when the case is closed again.
I usually glue it shut again and then wrap a strip of black electrician’s tape around it for good measure. Gluing is problematic though because some glues react badly with certain plastics. I’ve had “supa glue” actually melt some plastics and not even hold, instead of gluing them down.
The other 20% of the time the case cracks and is damaged but the adapter is still usable as it is only cosmetic damage.
