Where is backlight fuse on xz1 compact?
I have a xz1 compact with no backlight. I guess it's the backlight fuse since new display doesn't help.
Have big problem to locate the fuse since there is no V as in earlier models .
Any idea? Can't find any schematic and have no good board to compare diod values.
Hi @mexii ,
Have you checked if any images are visible on the screen by shining a torch at an angle close to the screen?
They will be very faint if they are there.
Just trying to verify if it is a backlight problem or something else.
由 jayeff 完成的
@jayeff
Hi,
Yes i have display, just no backlight. Touch works as well :)
由 Johan M 完成的
