跳转到主内容
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。相容的行動網路為2G、3G、3G+、4G(LTE)、4G+(LTE Advanced)。A2100僅有nano-SIM,其餘版本為nano-SIM與eSIM。儲存容量有64 GB/25B GB/512GB三種。顏色有銀色/太空灰(深空灰)/金色三種。(機器讀作iPhone 10s)
398 个问题 查看全部
Missing capacitor on motherboard
the capacitor (?) that I circled here is missing on my board. The phone doesn’t power on. Anyone knows what it does and what to replace it with?
update: I found it is c2721, where can I find these capacitors? (I live in the Netherlands)
another update: I got in touch with a motherboard repair shop who is going to give it a shot to repair. He has a ‘No cure No pay’ policy so I guess we’ll see. Thanks anyways!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
That missing capacitor would not stop the phone booting. What would be more important is why it is missing. That line I think is a CPU power line and since it has another 6 capacitors on that line I would not be concerned.
As for why your phone is not functioning we will need some more info.
·         How did the phone become like this?
·         Is it recognised by iTunes?
·         Does it draw any current before prompt to boot?
这个答案有帮助吗?
得分 3
1条评论:
It is not recognized by iTunes, neither does it draw any current. I don’t know how it got in this state. I bought the phone like this, the seller told the phone was dropped and not functioning after that.
I tried a screen and battery that were confirmed to work and I still did not get anything. The seller said there was never any work done to the motherboard but the shield and sticker covering that capacitor were missing. So I doubt that he’s telling the thruth.
完成的
添加一条评论
Not recommended solution
but try resolder it if you have an air solder(reflow station)
1.The hacky expensive way but sure that it will work is to get an donor of the same motherboard
Like phone with cracked screen, bootloop or something that the motherboard part that you need still works
And solder tha part that is missing
  1. get the same resistor value and same size
3. the RECOMMENDED way is to get a full working motherboard (like option 1) and replace the whole board
这个答案有帮助吗?
得分 0
添加一条评论
You can probably find a capacitor of that kind on the website LCSC.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
youri drent 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 19
总计 671
