跳转到主内容
加入维修社区 - 创建账户
The Lenovo Yoga 2 13" can convert from laptop to tablet, tent, or stand mode with hinges on the side. It was released in January 2014.
Why is laptop getting automatic shut down?
Whenever i'm turning on my laptop then preparing automatic repair option is coming and then the laptop is getting shut down. I thought that windows may have crashed but I'm also unable to open the boot menu option because before that the screen goes off and laptop shuts down.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
This is a very common problem i deal with all the time at my shop. The bootloop usually comes from two different issues. First issue is windows corruption. For example if a windows update got cut off or the computer got shut down multiple times incorrectly. The second usual issue is a bad hard drive. Now lenovo recovery is done actually with a button on the side of your computer depending on the model. If you take a paper clip and look on the left and right side of your laptop there should be a tiny hole. Sometimes the whole has an arrow next to it. IF you turn the pc off then insert a paperclip into that hole it will turn on and give you options for boot and recovery. Second option you have is making a windows bootable iso. There are plenty of videos on how to do that. You just need a 32GB flash drive and you can boot into that and reload windows. If that dosent work then you most likely have a bad hard drive.
这个答案有帮助吗?
得分 1
1条评论:
The solution is the one commented by Das Repair.
Additional information: You can use a 16GB USB to install windows 10.
完成的
添加一条评论
添加你的答案
suvankitprusti2000 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 64
总计 2,554
