跳转到主内容
于2019年11月发售的MacBook Pro 16''的维修指南和拆解信息。型号A2141,EMC 3347。
211 个问题 查看全部
MacBook Pro 16 inch 2019 - Can't remove one backplate screw
I have tried to remove the backplate on my Macbook Pro 16 inch, but I can’t figure out how to remove the last screw on the top left hand corner. I am using the correct tool to unscrew it, but when I try to unscrew it, it just spins in place. It won’t come out even after using a plastic pry tool, unscrewing it upside down and using a magnet . All the other screws remove just fine. Any advice?
https://drive.google.com/open?id=1dYgJGW...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Why are you trying to open up a machine that is still under full warranty?
There’s nothing upgradable in there.
这个答案有帮助吗?
得分 2
5条评论:
@mayer - I agree there is nothing upgradable, but if he had a spill or sat the system down on a wet surface he may want to check things.
Besides, he may want to marvel on Apple's design & finesse on the insides. ;-}
完成的
@danj Let him marvel via the teardown.
完成的
@mayer - What can I say ... The teardowns aren't in 3D ;-}
完成的
@danj The last 3D I watched was "Creature From the Black Lagoon" circa 1954 that was all I wanted from 3D
完成的
@mayer - Back in the '70's holograms where the big thing! Using a laser to burn a 3D image into a sheet of photographic film which you could look through and see an image was great fun! MIT-Museum Holograms.
完成的
添加一条评论
You’ll need to slide a few lassos of button thread around the head of the screw so you can lift the screw out as you twist it. I’m suspecting the screw machine which threads the screws to hold the bottom plate over torqued it so the thread edge of the case is damaged so the screw is still caught up.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Calvin Yang 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 504
