跳转到主内容
加入维修社区 - 创建账户
Ice maker won't fill with water
I just replaced my water supply line between the control valve and water filter on my Kenmore Elite refrigerator. I have good pressure and can dispense water with no problem. However, no water is dispensing to the ice maker. It worked fine before replacing the water line, and the ice maker is turned on. What could the problem be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hi,
What is the model number of the refrigerator?
完成的
添加一条评论
1个答案
已选择的解决方案
Here are some situations that can cause no water to ice maker. Starting with the most common.
A wire came off the water inlet valve.
A failed water inlet valve.
The ice maker is turned off
Tempature at ice maker isn’t below 9*f
Air in the water line
The ice maker hasn’t had enough time to cycle
A problem in the ice maker
The water line to ice maker froze.
这个答案有帮助吗?
得分 2
3条评论:
The light does not light when the ice maker is on position and cannot change size of cubes, but will dispense water.
完成的
Is there a different motor that runs the ice maker?
完成的
@barbararod54488
What is the
完成的
添加一条评论
添加你的答案
Mark T. 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 44
总计 6,951
