跳转到主内容
加入维修社区 - 创建账户
A1418/EMC3069/2017/3.0GHz四核心Intel Core i5、3.4GHz四核心Intel Core i5或3.6GHz四核心Intel Core i7处理器。于2017年6月8日发布。
Fitting second hard drive
I have a 21.5” 2017 iMac which has an Apple blade SSD (SM0512L) fitted.
I have removed the screen from the iMac and the 2.5” drive is totally empty.
I was thinking of mounting a 2.5” SATA SSD in this drive bay, but I am not sure if the SATA connector is in place.
Please confirm whether the SATA connector would normally be in place if a blade SSD has been fitted and if not whether it is possible to order the SATA connector nad mount a 2.5” drive as a second drive (leaving the blade drive as the boot drive)?
If the SATA cable needs to be connected, is it necessary to remove the logic board in order to plug in the cable>
Thanks for any help that you can provide.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The logic board connector is in place you’ll need to install the combo cable (SATA & Power).
iMac 21.5" (Late 2013-2017) SATA Cable
Yes, you’ll need to loosen the board to gain enough room to install the cable
Replace a broken or malfunctioning SATA Cable in your Late 2013 to 2017 model iMac 21.5" desktop computer.图片
产品
$12.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Darrell Haslam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 142
