E60-E3 Pop and crackling when powered up now no power at all.
When the power button was pushed it popped and made a crackling, fizzle sound of a burn. I found a burnt connector on the main board where 2 pink and 2 black wires go out to 2 individual connectors on the leds. The wires are completely burned off at the mainboard connector. I’m a novice at best but I know enough to keep from killing myself or burning down the house and the way I do that is ask questions. Based on my limited knowledge and from what I’ve learned by researching, I believe the problem is bad led strips. A short caused the burn. I’m not sure how to begin diagnosing the cause and the extent of the damage. Any assistance will be greatly appreciated.
Can you tell me if you found the problem and or fix for this same exact plug with heat stress.
由 Chris M 完成的
