跳转到主内容
Apple 的第三代智能手表,配备可选的蜂窝网络功能,发布与2017年9月22日。
197 个问题 查看全部
Lines on lcd after glass separation
Hi, before I have separated the cracked glass from lcd, everything was working fine but now once the screen is separated after connecting it to check if everything is okay, my screen has a lines on left hand side of the lcd, sometimes they are more visible and the other time less, do you think cleaning the connectors would help or the lcd is damaged ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sadly, the screen is damaged. Time for a new one.
这个答案有帮助吗?
得分 0
2条评论:
I was really careful with that so what could possibly go wrong?
完成的
The lines you see are caused by the TCON chip on the backside of the display assembly. What happens is the lines between the chip and display its self, a few lines have been damaged and when you apply a bit of pressure the connections make and break.
完成的
添加一条评论
添加你的答案
nosferatum2 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 351
