跳转到主内容
Can I use for a MBP A1151 a MBP A1212 Display?
Hi,
I have a MBP 17" Model A1151 and some problems with my display.
Now I found a used MBP A1212, with broken I/O-Board and broken Logic-Board, at eBay.
Can I use this display for my A1151?
Thanks for your help!
Greetings from Germany
BB
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hello!
Yes, you can use the display from A1212 for A1151, with one catch:
You will need to use the airport card from the A1212 machine. The reason is that the A1151 machines have 2 airport antennas coming from the display, and the A1212 machines have 3 airport antennas. Beyond this, you're set!
Good luck!
这个答案有帮助吗?
得分 2
添加一条评论
Hi Ben,
I have the flipside of the initial question.
Can I use a A1151 display in a A1229?
What issues might I encounter?
Thanks,
Charlie.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
B B 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 1,138
