跳转到主内容
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
153 个问题 查看全部
I have water leaking from the thermostat housing
I recently replaced the water pump, radiator, and the thermostat and housing now I can not get the thermostat housing to stop leaking. Just filling the car with water it pours out as fast as I pour it into the radiator, was not leaking before and I ha e tried 2 housing along with 2 gaskets………help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Hi,
Don’t know the answer but here’s an image of the thermostat removal and replacement procedure from the 2004-2005 Nissan Altima factory service repair manual (scroll down to Engine Cooling System) which may be of some help.
(click on image to enlarge for better viewing)
You mentioned gaskets but are the o-rings there and OK as well? Just a thought.
这个答案有帮助吗?
得分 0
添加一条评论
could be seals or maybe the thermostat is faulty, when and where is it leaking? is it leaking out the housing or where the housing attaches to pipes? is it leaking all the time, with the engine off and cold is it still leaking?
这个答案有帮助吗?
得分 0
添加一条评论
It is a factory haousing
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
magicman9911 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 643
