跳转到主内容
模具型号A1707。于2017年6月上市,这台MacBook Pro的特征为配有Kaby Lake处理器,可升级至2.9GHz、可动态超频至3.9GHz四核英特尔酷睿i7处理器。
327 个问题 查看全部
Swapped screens and screen only turns on in Recovery modes
I broke my screen and was able to get a known working replacement part from a friend. (the two screens look/fit identical but it is possible they are different parts).
The new screen fit in perfectly but only turns on when I get into a password reset or OS reinstall mode (OS Shell mode?). When I boot up normally, the laptop turns on but screen stays black.
I have rebooked 20 times and tried some cashe clearing but may have done it wrong.
Is this fixable?
Thx,
Evan
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Did u fix it ? i got the same problem !
完成的
添加一条评论
1个答案
The 2016 & 2017 models use the same display assembly, the 2018 & 2019 uses a different part.
Did you get the wrong part?
这个答案有帮助吗?
得分 0
2条评论:
ths for the answer , Its possible, but the screen turns on when in Password rest mode, looks perfect in that mode. I dont know how to check that year of the new monitor, but i'll look tonight, the promising thing for me, is the part is a perfect fit and match (visibly), same cables, colors, sizes on all thing
完成的
@ehovorka - Yes that is what will fool you! the displays look exactly the same! They are not electrically the same!
完成的
添加一条评论
添加你的答案
Evan Hovorka 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 44
