跳转到主内容
苹果于2015年10月14日发布的第二代桌面触控板。型号A1535。
12 个问题 查看全部
What type of glass is used in a Magic Trackpad 2?
Hi everyone,
I am keen on the reusing/recycling principle so I am considering purchasing a second hand trackpad that has its glass shattered and wanted to know the type of glass I should be looking for in order to replace it. I’ve already seen that Apple does not offer spare parts for the trackpad, but I’d look elsewhere for this. I was wondering if anyone has any info about the type of glass used in a Magic Trackpad 2 as I could not find anything online.
Thanks,
Nadgob
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
However, as you can see, there is nothing to be found about the glass replacement for the Magic Trackpad.
I figured there would be a lot of people like me who had this trouble waiting for a solution, so I contacted some glassmakers to make a sample and after replacing the glass myself, it worked great! I resurrected my Magic Trackpad!
If you are still looking for it. Please click through to my home page or watch the replacement video I posted. You will find the answer here [无效指南链接]
这个答案有帮助吗?
得分 1
2条评论:
@applerepaired - All you need to do is add in the parts source to your guide!
完成的
Good. I have submitted the changes. Thanks for the support! I hope more people who need help will see it.
完成的
添加一条评论
I’ve never tried taking the glass off the sensor plate, I’m not sure if you can. Apple has made many of its products in a way that makes it almost impossible to repair without leaving gashes and leaving the device structurally weak if even that!
If you can get the glass plate off I don’t think the glass is anything special.
Do us a favor! Take pics! And create a guide on what you learned Contribute
这个答案有帮助吗?
得分 0
2条评论:
Hi Dan,
I know, isnt’t it ‘smart’ for their pockets to make ‘unrepairable’ products??? Well, at least the EU has foreseen a new set of laws about and against planned obsolescence in order to avoid electronic waste, not sure if they are out already…
As soon as I check the damaged touchpad and it proves worth the effort, I’ll document the process and gladly share. I do fear though that it is made not to be repaired - or at least not without obvious or serious consequences…
完成的
@ermi - I hope you are supporting the Right to Repair movement in the EU.
We're getting close here! Still the products need to be repairable which is where the EU is pushing ahead of us.
完成的
添加一条评论
添加你的答案
Ermi Nadgob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 950
