跳转到主内容
Motorola released the Droid Turbo 2 in late October 2015. Model number XT1585.
29 个问题 查看全部
sim card is block for call, sim is not from verizon
I am using Moto Turbo 2 Droid, in start it work well, now it is blocked for SIM card giving error that, SIM card is not from Verizon but before it not giving error of SIM.
unable to start calling i setup SIM on global setting.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Verizon requires that the device be owned 60 days, then the device will be unlocked. Otherwise, other SIM cards will be rejected. Also, is the card GSM? Verizon phones are only CDMA-compatible.
这个答案有帮助吗?
得分 1
2条评论:
60 Days owned? what that mean?
Yes the card is GSM.
完成的
Well, there's your problem. Verizon only uses a CDMA network, which does NOT work with GSM cards.
完成的
添加一条评论
If your SIM card is blocked for calling, it's most likely because it's not from Verizon. In order to make calls on a Verizon network, your SIM card must be activated with Verizon. You can do this by either purchasing a SIM card from Verizon or by transferring your existing SIM card to Verizon. If you have an existing SIM card that you'd like to transfer to Verizon, please contact us and we'll be happy to assist you.
See more info https://grouphowto.com/verizon-sim-card-...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kamran Shah 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 352
