跳转到主内容
修复Nintendo Switch Joy-Con控制器的指南和信息。
167 个问题 查看全部
Left Joy-Con dead, doesn't work attached to the switch or not
My Joy-Con has been dead for a while. It doesn’t even turn on, no lights flash on the side rail while on the Switch or off. I have opened up both controllers, and swapped the battery as the right Joy-Con still worked. Good battery doesn’t work. “Bad” battery found in dead JC works on good Joy-Con. Not a battery problem. Any help is greatly appreciated. Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
6条评论
OK so i have fixed a few dozen Joy-cons and to my Knowledge it is a slider rail problem in the slider rail it contains the charging port at the bottom of the joy-con when slid into the switch console. a replacement rail should be fairly easy to acquire through such sites as amazon / ebay / Aliexpress etc.
完成的
Thanks p_smith, I've just ordered some rails from Aliexpress
完成的
@p_smith I fixed mine, it was a motherboard issue
完成的
@wispysmoke what did you replace/fix?
完成的
@mrwyyeet The entire motherboard. I have a boneyard of joy-con parts, and found a spare working motherboard. It turned back on and worked swimmingly. Not sure which part on the mobo went dead but figured it was a mobo issue.
完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
Hi!
I’m afraid it’s motherboard related. You could inspect the motherboard if you can find something which is the cause. Otherwise there is not much left to do… Maybe someone else here knows which component you need to replace on the motherboard it self (requires soldering most of the time).
这个答案有帮助吗?
得分 4
1条评论:
Wrong, as another JC left will work, so motherboard works well. I'm in the same situation and the proof Is that if i take a JC left from another switch and the put It on mine, It Will be recognized and charged...
Something strange must have happened to the JC left, there are no other alternatives
完成的
添加一条评论
添加你的答案
Brady Cook 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 35
总计 9,634
