跳转到主内容
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
315 个问题 查看全部
MacBook air (mid 2009) beeps every five seconds after keyboard connect
Hi!
So, I was trying to fix a mid 2009 (A1304) macbook air and concluded the keyboard was probably broken. So, I disconnected the ribbon cable for the keyboard and started the macbook using the power pads, and it worked!
Genius as I am, I (let’s say accidentally) reconnected the keyboard ribbon connector while the computer was booting. After that, it will only give me a beep every five seconds.
Now, I know this is stating there is a ram problem, but since the ram on a macbook air is soldered onto the logic board… does this mean this macbook air is probably fried?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Ouch! Not good!
Yes you do need to make sure things are off before connecting or reconnecting things. Time for a new logic board sorry ;-{
这个答案有帮助吗?
得分 1
1条评论:
If that's the case, it's time for the trashcan
完成的
添加一条评论
添加你的答案
Timbobs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 86
