跳转到主内容
The 360fly 4K is a camcorder capable of capturing both 360 degree and point of view recordings in 4K resolution. It can be identified by it size and weight: a 61 millimeters sphere and 172 grams.
6 个问题 查看全部
The LEDs suddenly stopped turning on
Suddenly, all of the LEDs stopped functioning. The rest of the camera works fine and i did not have it under or near water. When i took it apart, i found that one of five of the smd LEDs on the pcb had charred lines that run into the smd. I'm not sure if it's just an smd that needs to be replaced or a larger issue. Perhaps the board is specifically for the LEDs and is fried?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @myers13skulls ,
The LED, LED driver and associated components (bit hard to see in the pic what is missing in comparison to the other LEDs) is certainly damaged and/or burnt out.
Could be just component failure that caused this. Certainly looks like excess current flow through the components.
Try searching online for (insert "board" number of LED board) schematic to hopefully find a schematic diagram of the pcb which will make it easier to diagnose if anything else is faulty or what may have caused this to happen.
Alternatively, this may be an option to consider, if you can't find the schematics and the price is right.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Myers 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 104
