跳转到主内容
苹果为桌上型或笔记本 Mac 电脑设计的操作系统。
Trying to install El Capitan on iMac
My MacBook is running Mojave and I need to instal El Capitan on my iMac (what was on it before I needed to replace a bad hard drive).
I can’t get it to download using my MacBook through legitimate Apple sources.
HELP! That link Aaron provided is from Apple and since I am running Mojave I can’t download it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
So if anyone had this same problem and could help me before I pull ALL of my hair out that would be greatly appreciated!
完成的
Same here, any luck?
完成的
did you get to the bottom of this? im in exactly the same situation
完成的
添加一条评论
1个答案
Depending on the age of your iMac you should be able to install your new SSD into your system and then run the Internet restore using the start up keys: Command (⌘) & R keys
Reference: About macOS Recovery
To gain access to the older macOS’s use the startup keys Shift & Option-⌘ & R keys
Reference: Reinstall from macOS Recovery
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
amanda819 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 622
