跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Why won't my key stay on my keyboard?
I had a few stuck keys that I removed carefully to clean last week. All of the keys work fine now except my “W” key. The hinge itself will not stay clicked into the keyboard at all.
Every time that I put the hinge down, I put the keycap back on and the whole key falls off with the hinge stuck to it after pressing on it a couple of times. The hinge itself doesn’t seem to be broken or anything. I hope this is an easy fix if anyone can tell me what’s wrong.
Edit: I never took the clip/hinge off originally, it started coming off with the key today
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You’ll need to get a replacement scissor assembly as the clips are likely damaged. Here’s a good source for the needed parts Retina MacBook Pro 2012-2015 Keycap parts
这个答案有帮助吗?
得分 1
4条评论:
I figured as much but was hopeful considering the clip still connects to the keycap itself without issue. Thank you
完成的
I took another key off and tried using the clip from it for the "w" key and the same issue is happening. I put the clip back on the original key and it still works for it.
完成的
Compare the metal tabs between the keys the scissor hinge clips to are they bent?
How about posting a good set of pics so we can see. Your other pics are too blurry. Try to add some light and use a tripod or other object to rest the phone or camera to steady it. And lastly zoomed in as tight as you can and still be sharp.
完成的
My bad with the pictures. I just compared clips and the hole on the w key is actually wider than the r key. I will order a new clip, thanks for responding!
完成的
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 4,554
