跳转到主内容
Problem while replacing SSD on MacBook Air 11
Hello,
I bought a Trascend Jet Drive SSD and have been trying to do a backup copy onto it in order to replace my current SSD with it. I’ve tried following the instructions of the manufacturer, which tells you to use Disk utility to back up, but I keep getting “input/output error” and no back up is made. I have been trying to search for a solution but only found that FileVault should be disabled, which it already was. Is there any other way to do this?
My computer is a MacBook Air 11” mid-2011 version 10.11.6.
I appreciate any ideas :) !
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I think you really need to use a different approach than using Disk Utilities imaging service. How about using the Apple Migration service instead. Here you’ll first need to have a bootable external drive running the OS you are currently using. Run the installer and at the end you’ll be greated with the question if you want to migrate your user accounts, apps & data from another system you will want to do this to copy off your stuff to the external drive. Once you’ve done that after you reboot your external drive should be the booting drive. Check your apps and data if everything looks OK, swap out your internal drives and redo the same process. That should do it.
这个答案有帮助吗?
得分 2
添加一条评论
You can't Device is mounted and in use, disk utility is too limited for this easy task. You can clone it with a external bootable macOS.
Easy and free way on your existing macOs is Carbon Copy Cloner (Google It) easy 2 clicks full copy or your macOS.
这个答案有帮助吗?
得分 1
1条评论:
FYI - The imaging service within Disk Utility (older versions of OS-X & macOS) is just like Carbon Copy Cloner. So in this case a bad drive can't be cloned as the corruption won't allow it. I also find too many failures with cloning apps (any) and have long since stopped using them.
完成的
添加一条评论
添加你的答案
Anna 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 139
