跳转到主内容
Canon's PowerShot SX200 IS is a 12-megapixel compact camera with manual controls, released in 2009. Features include a wide-angle lens, 12x zoom, and 720p HD video.
6 个问题 查看全部
My SD card won't lock. Help?
The SD card in my camera has stopped locking into place for no apparent reason at all. I havetried using a different SD card, so it’s a problem with the camera. It still works, because it is held down by the battery cover, but it’s a right nuisance. Can anybody help me?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The spring mechanism on the SD card slot is broken. Canon solders it onto the primary PCB in the point and shoot cameras, so you need to repair the board or replace the entire PCB.
The problem is cost. In a lot of cases, board replacement tends to be as much as another camera (or an upgrade) so it is rarely worth doing. Because of that, you’re usually better off trying to solder a new SD slot on and hoping for the best. If that fails, time for a new camera.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Daniel Chamberlin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 239
