跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
问题已关闭
Replaced Lcd Screen and it doesnt respond at all
i just relpaced my lcd screen on my iphone 3g now the screen is black none of the buttons respond but i can plug it into itunes and it syncs fine. my questions is what is causeing this and how do i fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
hi Dears
After digitizer replacement for iPhone 3g is out of screen I can't power on and charging the device when I try to turn on the device is only a light screen for 3 seconds and come off . When I plug it to the charger or computer is not responding
Is there a way to fix this?
thanks
完成的
Is there a way to make Reset in the Motherboard or something like that ??
Couse all the cables and conections its placed and plugs good !!
完成的
添加一条评论
3个答案
最有帮助的答案
If the iPhone was powered up without the screen connected, it will not work. Try to use the "Home and Power" button reset. If that doesn't work, you'll have to remove and reinstall the battery.
这个答案有帮助吗?
得分 1
添加一条评论
You may have installed it incorrectly, go back through the process of installation and remove the display then install it again, but carefully this time.
这个答案有帮助吗?
得分 1
添加一条评论
hi Dears
thanks
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,429
