跳转到主内容
LTE-enabled variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
20 个问题 查看全部
Digitizer Ghost touching after replacing digitizer
i recently replaced my ipad 5 LTE digitizer and it was working fine after the repair but the home button was loose so i figured ill put some glue on the piece that holds it in place and it’ll stick. It fixed my issue but now i have a lot of “ghost touch” on the display.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Check that there isn’t any pressure applied to the screen around where it’s ghosting. If you had to remove the display to fix the home button issue, you could’ve damaged the digitizer flex cable.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kamil Malec 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 103
