Why is my iPhone 8 plus screen dim?
Hello everyone ,
So I bought a used iPhone 8 plus from ebay but when I power it on I noticed the left corner of the screen looks dim so should I buy screen replacement or could the motherboard be damaged?
This is a faulty component on the backlight circuit. It is becoming an increasing problem with the 8 plus. Usually it is a small resistor which has failed causing the screen dimming in that exact place.
You will need to find a repair shop that does microsoldering. It will be a fairly cheap repair.
这个答案有帮助吗?
You can put a new screen on and test. If the screen remains half backlight, then it’s a logic board problem.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 147
