跳转到主内容
Announced on July 2015, this is Motorola's flagship phone. It has a 21 mega pixel camera with a 5.7 inch IPS TFT LCD screen with a resolution of 1440 x 2560 making it Quad HD. Model number XT1570, XT1579, XT1575 and XT1578.
61 个问题 查看全部
Not charging or turning on
Phone was working.
Battery was low, showing the batt pic with the red line…. when I plugged it in, looked like it was charging, but didn’t,
Re tried on different charger still no charge. Both are good chargers.
also, when pluued into charger , won’t turn on ? should it ?
Any ideas ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Has there been any trauma to the device recently? A drop? Liquid damage? If not I would suspect the charge port is the problem.
A quick google search would suggest that there have been issues with slow charging on this model so it would make sense to follow good practice and make sure there are no background apps running and that the charge port is clean then attempt charging again.
这个答案有帮助吗?
得分 0
添加一条评论
Sometimes, it isn’t the charger, but the wire from the charger to the phone. Try using a different cable
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 178
