跳转到主内容
加入维修社区 - 创建账户
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
Charging problems out of ordinary.
Just recently, my iPhone 7 Plus has been giving me fits with charging. At first I assumed it was a bad cord, but I have bought several new ones and that is not the issue. When I plug the charger into my phone, it will charge if it sits still in one place, and sometimes not even then. For the most part, it rapidly charges and uncharges. I have cleaned the charge port with a toothpick, toothbrush, and napkin even. Is this a bad charge port problem? I’m confused, any help would be greatly appreciated. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
My wife's iPhone 6S has been having some weird power problems too. It ate a battery the day before Christmas, so we got that replaced using the insurance that she has on it. Since then it's been running really hot and discharging the battery quickly if it in unplugged. When it's plugged in, it stays charged and the temps are OK. I called Verizon last week and they are sending out a replacement phone.
完成的
添加一条评论
2个答案
已选择的解决方案
First you need to install a new battery then dock connector. This will rule out parts. A phone that is charging and discharging fast is usually caused by a bad battery. Have a look with it connected to a PC with 3uTools installed and see what the battery health is.
这个答案有帮助吗?
得分 2
添加一条评论
Good Evening,
A good thing to do first is to use compressed air on the charging port to clear out the dust particles out more effectively. I would hesitate to use the toothpick you used to clean it again as if you poke around too harshly or forcefully you can actually damage the charging pins and cause more issues.
If it is sensitive to the position it is being charged in, it sounds more like a bad charging port or a dirt/lint issue. But otherwise, you can try and see what the battery health is at and see if it needs to be replaced. I would try the compressed air before anything else because the simplest solutions could avoid opening the phone and replacing a part that didn’t need to be replaced. If the cleaning and battery replacement just aren’t cutting it, then you may need to replace the charging port.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tyler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 95
