跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
Front facing camera don't work after shell replacement
Hello,
I’ve got the same problem with an iphone 8 and an 8 plus.
The back was cracked so I change the shell, everything work fine except for the front facing camera.
I’ve tried hard reset, reinstall, DFU, repluging the flex cable, replacing the part and nothing seems to be working.
I’ve take caution when unplunging the flex cable, nothing seems to have moved under the foam covering.
Some got an idea ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
try swapping a know good front cam and back cam into the device, if that works then replace the old back cam and see if it still works and vice versa. had a few give me crap from time to time but maybe that helps.
这个答案有帮助吗?
得分 0
2条评论:
Well, i've no problems with the back cam, they work like a charm.
And the front camera was working prior to the shell replacements.
And I've try with an known good, and it's doesn't work either.
完成的
sounds like maybe a fpc connector. is your flash working? sounds like a stupid question but its all on the same circuit.
完成的
添加一条评论
添加你的答案
freyjamir 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 69
