跳转到主内容
Fin stack sensor and Kernal task - replace logic board?
Hello,
All the sudden my computer started running really slow. Activity Monitor shows “Kernal_task” using 300-1000% of CPU power and fans were running on high. Computer is effectively useless because it runs so slow. Took too the apple store and they said “Fin stack” sensor had failed their hardware tests and the entire logic board needed to be replaced for $500.
Resetting SMC and PRAM had no effect. They attempted 100% erase and install but it would take forever and never finish.
Can replacement be done for cheaper DIY? Is the “finstack” sensor on my model located on the logic board or motherboard or this that the same thing?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Checkout this dialog: Th1h Fin Stack sensor failing
完成的
添加一条评论
1个答案
Here’s the guide: MacBook Air 13" Early 2014 Logic Board Replacement and here’s the needed part MacBook Air 13" (Mid 2013-Early 2014) 1.4 GHz Logic Board
Replace a 1.4 GHz logic board (motherboard) compatible with the early 2014 MacBook Air 13" model laptop. Fix processing issues like unexpected shutdowns, reboots or water damage.图片
产品
$152.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 378
