跳转到主内容
The 2013 revamp of the desktop Mac series known as the Mac Pro.
2-3 second grinding noise on startup
There’s a short (2-3 second) grinding noise at the beginning of startup, before anything appears on the screen. I’ve taken the cover off and the fan is rotating ok. Any idea what it might be? It works ok, just worrisome.
Update (03/14/2020)
I replaced the fan. It doesn’t work. I think I may have damaged one of the electrical ribbons, going to see if shop can fix. But also, still have the grinding noise. Video attached.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Has to be the fan.
完成的
添加一条评论
1个答案
最有帮助的答案
A grinding noise implies physical movement, and as the only moving part inside the Mac Pro is the fan that kind of narrows the possibilities.
这个答案有帮助吗?
得分 1
4条评论:
I know, but the fan spins freely no noise, after shut down and opening the can. What initiates the fan movement on startup?
完成的
The fan is little more than a self-cooling electric motor. I would guess that the fan is either slightly off-balance or the bearings are slightly worn, and at startup (low RPM — but faster than you can spin by hand) it wobbles enough to make noise. Once it gets up to speed it stabilizes enough that it stops making noise. If this is correct, your fan will get gradually worse until it fails completely.
完成的
Thanks. Makes sense. Find a new fan and do this: Mac Pro Late 2013 Fan Replacement. Some of the comments under this sound familar.
完成的
There is a non-moving part that can make a noise.
完成的
添加一条评论
添加你的答案
John Cathey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 519
