跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
How to restore an iP5s with baseband problem?
Hi all,
I have a problem restoring my iP5s. In fact, I have tried to restore the phone many times but the restoring process always stops running at updating baseband step. I even now cannot turn the phone on. Particularly, whenever I press the power button, the Apple logo shortly appears and then quickly disappears. Any suggestion is much appreciated.
Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
unfortunately that base band ic is married to everything else in the board if memory serves me correctly. you might be fighting a uphill battle with it.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for your comments, meaning that there is no way to restore my phone?
完成的
添加一条评论
You probably ending up with error -1
you need to fix your baseband.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for your advice, however, how to fix the baseband? Replacing the old one with the new one?
完成的
添加一条评论
添加你的答案
Dung Le 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 1,029
