跳转到主内容
The Odyssey was introduced in 1994 as Honda's first minivan — based on the Accord platform, with a 4-cylinder engine, all-disc anti-lock braking, all wishbone suspension, and a four-speed automatic transmission with a steering-column-mounted shifter and a hill-hold feature, marketed as Grade Logic.
5 个问题 查看全部
Why is my transmission light flashing
The transmission system doesn't select well whenever the drive light on the dashboard goes off
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
Check that ATF (automatic transmission fluid) level in the vehicle is at the correct level and that it is clean and doesn’t smell burnt at all.
The transmission fluid should be replaced every 48,000 Km (30,000 miles)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Okechukwu Chukwu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 152
