跳转到主内容
与AirPort Extreme基站一起发布,这款配备硬盘的Time Capsule NAS上提供802.11ac速度。
20 个问题 查看全部
Airport Time Capsule 2TB A1470 - WAN port not responding
I am having trouble setting up a used Time Capsule (A1470) as a standalone Wireless Router. I can’t seem to get the WAN port to respond when I connect it to my cable modem. When I daisy chain the TC to my existing Applie Airport Extreme (using the LAN port), I can use the Time Capsule fine -But not as its own wireless router and storage solution.
I brought it to apple who couldn’t help (out of warranty), but I am wondering if anyone has experience either replacing the WAN port or the entire logic board that it is attached to.
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hey there. The only idea I have is to try with a different Ethernet cable - and not just another one. See there are two ways to wire those cables - crossover (or sometimes called uplink) and standard. Newer devices can detect the connection type and adapt automatically and Airport devices certainly know that trick, but I’m not sure about your modem. Look at the wiring diagrams below - find which one is used on your cable and try with a different one:
If you can’t buy a cable wired the way you need - it’s quite easy to make it - just check this guide
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sam Kolinsky 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 8
总计 123
