跳转到主内容
Safari can’t find the server
I recently found an iBook G4 and I put an Airport Card in it to connect to my home wifi. On the Network section there is a green dot next to AirPort. The Mac OS X is 10.3.9. Do I need to upgrade to Leopard before Safari will work? Or what else do I need to do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Will it connect via an ethernet cable?
完成的
Yes I can via an ethernet cable but only some sites come up. When sites to come up they aren't complete and no pictures.
完成的
添加一条评论
1个答案
You need to use a browser other than Safari. Most web servers these days use secure connections (https) which may be too advanced for Safari to comprehend. If you can upgrade to 10.4 then I’d recommend TenFourFox, otherwise look towards iCab (v4.9 is the latest that’ll run on 10.3).
这个答案有帮助吗?
得分 0
2条评论:
Can I upgrade to 10.5 then download another Web browser?
完成的
Yes. I'd still recommend TenFourFox in that case. Be aware that there are different builds of TenFourFox depending on your processor, so be sure to download the correct version for your machine.
完成的
添加一条评论
添加你的答案
Ryan Mueller 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 16
总计 414
