跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
20 个问题 查看全部
Help Removing Stripped BackPlate Screws?
So I had a new Backplate for christmas and was happy to finally replace old plate because of all the scratches, but when I was removing the screws I accidentally stripped 3... Do you guys have any ideas on how to remove those 3 stripped screws?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 10
1条评论
You might be able to use tiny screw extractors like these that iFixit sells:
Precision Screw Extractor Set
Given that the casing is plastic, I wouldn't recommend trying to drill the screw out like you might do with a broken bolt in metal. I also don't think they make a set of easy outs small enough to get those Switch back plate screws out.
完成的
添加一条评论
2个答案
最有帮助的答案
Haven’t done this yet, but my father, whose job was fixing motherboards and other electronical parts, said that the only way is to drill where the screw is, with a drill head as big as the screw itself :/
这个答案有帮助吗?
得分 1
1条评论:
I had to do this on my own Switch recently. It's nerve-wracking but as long as you're careful it gets the job done.
完成的
添加一条评论
One thing that’s worked really well for me in the past is to put a flat rubber band between the screw and the screwdriver and PUSH — the pressure and added tackiness of the rubberband will allow for the screwdriver to have a better “grip” and get those out.
Also, you’re not alone. Those OEM Switch screws are EASY to strip.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Vince Mada 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 28
总计 4,784
