跳转到主内容
Repair guides and troubleshooting for the Whirlpool Quiet Partner II insulated dishwasher.
53 个问题 查看全部
Dishwasher not starting. All lights working.
I have a Whirlpool Quiet Partner II. Yesterday, I noticed that while other buttons were working (i.e. the cancel button), the start button would not work when pressed.
I have reset the control panel by pressing sani-rinse, heated dry, sani-rise.
  • When I do so, the start button lights up with all the other buttons.
  • I then close the door, and Start/Resume turns on. The dishwasher makes a loud sound on the normal cycle, washing status, then it hums, makes a sound like it is draining
  • It then goes to the rinse only cycle and washing status, and continues to hum/drain
  • Finally, all the lights turn back on
When this is over, I still cannot get the start button to work.
Any thoughts are appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
When you push the start button do any lights flash?
If the clean light flashes seven times you have a heater error and the board is locked out. You will have to diagnose whether the problem is the board, heater, tco ot thermister.
If a light above a button flashes quickly it means that button is stuck and the console with UI needs to be replaced.
If there is no response whatsoever from the unit when the start button is pressed chances are the console with the UI needs to be replaced.
You can use the model number to find the part on any number of sites. If you replace the console I would strongly recommend replacing the board thermal fuse as well, it tends to go out a few days after touching the wires in the control area.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Becky Armstrong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 903
