跳转到主内容
Repair guides and support for LED, LCD, HD and other Vizio TVs.
932 个问题 查看全部
Does anybody know how to fix a flickering screen?
I have a 22” VIZIO model with a built-in stand. When I turn it on, the light usually flickers, and so does the screen. The light is old, and likely is dimming with age. The screen issues started with the bottom half sometimes dimming for small periods of time. This soon elongated, and then started occurring with the top half instead. Later, this began happening with the entire screen. Now, the screen flickers rapidly, dim and normal brightness. (Also, the remote broke a while ago, so, is there a place where a remote for this TV is available?)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
In this scenario, the LCD or backlight cable may be loose. If this is not the issue, then the problem is in either the motherboard or display. As for the remote, you can check with the manufacturer, or can find a replacement on second-hand sites like eBay or buy a universal remote (I have NEVER had luck with these, use them as a last resort).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Michael Deitz 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 27
过去 30 天: 89
总计 1,170
