跳转到主内容
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
133 个问题 查看全部
Black screen,no sound,cant reset
My Tab 2 10.1 wont boot (does vibrate so its turning on),shows no screen,no start up sound. Tried hard rest, nothing on screen.I reset all cables, unplugged battery. There is white light coming from behind the lcd inside. What do you think needs replacing?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @dirktooth,
Since you have reseated the cable (both ends - presumably not damaged or connectors corroded - did the tablet get wet or was it dropped at all?) between the systemboard and the display assembly unfortunately as a DIY repair the way to prove whether the problem is in the screen or the systemboard is to temporarily replace the screen and check the result.
No audio is also a problem but until you can “see” you don’t know what is happening in regards to the audio.
It may be a systemboard problem affecting both video and audio or it may be two separate problems. If you think that it has turned on did you try increasing/decreasing the Volume to see if an audio is there when touching keys etc?
Replacement screens are available online. Just search for Galaxy Tab 2 10.1 LCD screen to get results for suppliers.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Brian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 142
