跳转到主内容
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
How to connect ThunderBolt Display to MacMini through Firewire
Hello,
I have a MacMini 2012 which it’s thunderbolt chip is not functioning. I really do not want to spend money on repairing it. I also have a Thunderbolt display which I was working with it before the MacMini chip broke.
Now would you please let me know if there is a way to connect my Thunderbolt display to my MacMini with a adapter from TB2 to Firewire or HTMI ?
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You facing the same issue as having two people who can’t speak the others language. There is just no way for the two to have a conversation! You can’t use the FirWire connection to connect a miniDisplayPort or Thunderbolt display. There is just no means to make that work.
Your system does come with a HDMI port which you can connect a HDMI connected display. The other alternative is connect a second Mac via Ethernet between the two systems and then use Remote Desktop to then run your apps via the other Mac. Basically, running it headless. Thats what I do to manage my Mac Mini as a media server. Here I run iTunes to download and mange my music, video and podcast media.
这个答案有帮助吗?
得分 1
2条评论:
Dear Dan,
Thank you for the straight forward answer. Then I would need to weather buy a new Mac Mini or forget using my Thunderbolt display.
All the best,
Al
完成的
Sounds like you had your heart set on the Thunderbolt display. Yes its a great display!
Where do you live? Country and nearest city? Maybe someone can fix your logic board or see if a replacement logic board would be possible. Either option should be cheaper than getting a new Mac mini, unless yours is just underpowered for what your needs are.
完成的
添加一条评论
添加你的答案
A.Ch 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 384
