跳转到主内容
加入维修社区 - 创建账户
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
Unbootable MacBook Pro can't boot up through an external HD
I have a MacBookPro 2015 with High Sierra. It can't boot up. It is stuck at the startup black background with apple logo and the progress bar. In verbose mode, I saw I/O errors. I think the SSD is having problems. I want to get some files from the internal drive. I have a hard time booting into the internal drive recovery mode. I can boot into the internet receovery mode, but it takes a long time.
So I boot into the recovery mode with a thumb drive (a bootable High Sierra installation drive). However, I have problem creating disk image of the internal drive or recover the internal drive to an external drive with Disk Utility. I have tried with terminal to copy the files/directories from internal to external, but cp/mv commands do not work:-(
So I have installed Mojave MacOS on an external USB drive from a new iMac with Mojave. The external drive can boot up the iMac. But the Startup Manager in the recovery mode (through thumb drive) can't see the external drive! I unplug the thumb drive, and the thumb drive and EFI boot are unmounted. I plug the thumb drive back, and those 2 drives show up again. So I try this with the external drive, but it still can not see the external drive with Mojave. How can I boot up the MacBook Pro with my external drive?
Any suggestion is much appreciated!:-)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Other solution would be to remove the back plate of your Macbook and remove the SSD.
On ebay or even Amazon you can find adapters from your SSD to usb so you can connect you drive tu other Mac and recover your data.
这个答案有帮助吗?
得分 2
1条评论:
Unfortunately, I am currently not in US, and it is not easy to get the adapter. But that is a good suggestion if I can get the adapter:-)
完成的
添加一条评论
添加你的答案
Tom168 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 312
