跳转到主内容
于 2014 年 10 月 16 日发布,型号为 A1347 和 EMC 2840。
PPM002 Error in Diagnostics but memory tests pass
Hello
I have a Mac mini Late 2014, it works fine when im using it but cannot update OS not install new one, each time I try to do it, it comes with up error and points to running diagnostics due to a hardware fault. Ran diagnostics and came back with PPM002 error pointing to an issue with memory module (crappy onboard on this version of Mac mini so can't replace). However when I Run a memory test software like Rember (I've tried a couple of others too) all memory tests come back with no issues. I've attached pics of the diagnostics screen as well as the memory tests.
Any help is appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Did you try a fresh set of SO-DIMM’s?
What is the amount of RAM you have mounted?
Sadly RAM testers are not perfect! I would trust Apples as it tests the lower range better than OS run testers which can't reach the lower address lines.
完成的
The RAM is soldered on this Mac unfortunately otherwise would have tried before posting the question.
完成的
Your right I was thinking the older 2012 model! My mistake. Need that second cup of coffee this morning ;-}
完成的
添加一条评论
2个答案
最有帮助的答案
Sadly your logic board has a problem with one of the RAM modules.
这个答案有帮助吗?
得分 2
添加一条评论
Hi!
I created an Utility you can execute before you boot into MacOs which marks the defective RAM-Areas so that macOs doesn't attempt to access them. It runs successfully on my MacBookPro 2013 and I also have reports now that somebody managed to get it work on MacBookPro 2019. You can check it out here:
https://github.com/0nelight/macOS-Disabl...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Faisal Gondal 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 7,711
