跳转到主内容
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150 个问题 查看全部
Red 12V ignition wire has no power
I’m installing aftermarket radio on my 05 Pontiac grand am. It’s not powering up, I checked all the wire they all have power except the red ignition wire. I checked all the fuses they are good. Don’t know what else to do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @ashtonssss ,
Here’s a link to the radio wiring colours for your model vehicle. Scroll down the page to view the wire colours and the function of the wire.
There is no mention of a “red” wire for power but if you mean the wire for switched accessories power then if it is already run in then you will have to trace where it goes as the link states that it is not provided and has to be run in.
The constant power supply from the battery is an orange wire.
Hopefully this is of some help.
这个答案有帮助吗?
得分 1
添加一条评论
Had this same problem man. There is not an accessory wire to connect the red wire to. You have to wire it to your external fuse box under the hood. I believe its number 38. It will say cigar lighter/auxiliary. Wire it to that and it's best to put a fuse in between them so only the radio will go out if a fuse blows
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ashton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 1,844
