MacBook Pro don't sleep, stuck on load screen while using
Hi everyone I got this 2015 MacBook Pro retina 15 inches.
It don’t enter in sleep mode when lid is closed, either with apple menu - -> sleep . it do absolutely nothing. I changed the ssd and put in a new one with a fresh Mojave install, so no software related, but if I run safe mode sleep mode works perfectly (even with a external display connected, so I exclude a gpu problem).
Another problem with this Mac it that while using it randomly stuck on boot loading (yes, I have a normal application open and it go back to black screen with white apple and progress bar, nothing move more for hours). This also don’t happens in safe mode.
I don’t have any idea of what is happening here
Update (02/04/2020)
OK. I replace hall sensor.
Same issue!
Any ideas?
I noticed some artifacts when system is booting, the apple logo is flickering a bit. maybe we have a GPU fail? welcome back AMD ... We are back in 2011 %#*@
UPDATE:
As I said this morning I replaced the hall sensor, without any hope of success, only because I got a replacement and I wanted to try everything without giving up.
After that, I have the same identical issue. I don’t perform PRAM or SMC reset (as I said, I don't believe in this fix).
I use the MacBook as normal, I forgot it with power on (of course I don’t have sleep mode) so the battery completely drain an the MacBook turn of itself. I plugged in the charger and let it charge for a couple of hours and when I power it on I see the black screen with “your computer shut down for a problem” and now everything works great, sleep mode is OK, closing the lid works and everything looks good.
So, I have to believe that hall sensor could be the solution (but without the PRAM and SMC reset), or that is somehow related with battery?
I will update the post if the problem reappears.
Thanks
Update (02/12/2020)
Hi,
Sleep problem goes away with new hall sensor, now I have random shutdown, plus always crash when I connect an HDMI monitor. I have different kernel panics
panic(cpu 4 caller 0xffffff7f97040ad5): userspace watchdog timeout: no successful checkins from com.apple.WindowServer in 120 seconds
service: com.apple.logd, total successful checkins since load (200 seconds ago): 21, last successful checkin: 0 seconds ago
panic(cpu 0 caller 0xffffff7f8439c75a): "virtual bool AMD7000Controller::detectPowerDown(): GPU is not found. PCI config access fails!!!
"@/BuildRoot/Library/Caches/com.apple.xbs/Sources/GPUDriversAMD/GPUDriversAMD-3.5.5/Common/IONDRV/ATI/IOFramebuffer/ATIFramebuffer/Abstraction/Sources/ATIController.cpp:3125
Sleep transition timed out after 180 seconds while entering darkwake on way to sleep. Suspected bundle: com.apple.iokit.IOGraphicsFamily.
panic(cpu 4 caller 0xffffff7f83c40ad5): userspace watchdog timeout: no successful checkins from com.apple.WindowServer in 120 seconds
2条评论
What make and model is your SSD drive? Is it an M.2 held in an adapter frame?
由 DanJ 完成的
nope, both are original samsung ssd , both give problems. both works good in other MacBook
im downloading now Catalina to see if something change.
catalina installed, same issues
由 Paolo Cadeddu 完成的
