跳转到主内容
Repair guides and support for your Samsung TV.
2610 个问题 查看全部
Pixel "stains" of different color on top part of the screen
Hi all, yesterday I noticed that the upper part of my tv started to have some “stains” of pixels showing colors different than what they are supposed to be.
Normally these stains are of a light blue color when on the screen there is a bright image, then they turn black if there is a completely red background and when there is a black image they are completely unnoticeable.
I also noticed that if I look closely with a flashlight these stains sort of remain even when the tv is turned off.
I never spilled water on it or anything, actually i never even moved the tv in 4 years.
Any idea what it could be? (TV model: Samsung UE55JU6400)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi @vladp ,
Have you tried adjusting the picture Zoom or Custom position up and down to see if it resolves the problem?
Go to (MENU/123) > MENU Picture > Picture Size > Picture Size > Try Now
Here’s a link to the user manual. Scroll to p.121/194 (pdf file numbering at top of document) to view all the options for moving the picture so as to remove the line from the top.
这个答案有帮助吗?
得分 2
添加一条评论
it could be that air is getting into the lcd
这个答案有帮助吗?
得分 0
3条评论:
Gage, Whaaaaaat? Can you please elaborate on that?
完成的
I have seen that Samsung phones have had air get in between the LCD layers in cases similar to this
完成的
This could probably be the cause, after a while I noticed some screws on the back of the tv were a bit loose and there was a small gap between the panel and the rest of the tv.
完成的
添加一条评论
添加你的答案
Vlad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 545
