跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
Firmware verification fails when installing High Sierra
I replaced the Logic Board AND SSD of my Mid2015 Retina MBP.
I’ve got a board from iFixit and used an Aura N SSD which is supported from Sierra on (El Capitan did not recognize the internal SSD but I was able to install to an external USB Drive) I managed to install Sierra.
Upgrading from Sierra to High Sierra fails after a reboot with the “macOS could not be installed on your computer. An error occurred while verifying the firmware” message.
How can I install macOS > Sierra?
Model: MBP, 11.5
Boot Rom Version: MBP114.0172.B25
Thankful for any help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
There’s a few different issues you could be facing!
The first is if you are trying to install High Sierra or Mojave Apple messed up the certificates pre-maturing expiring them! Here’s more If you've got an old macOS install image, it will probably stop working today
Here’s the fixed installers:
If you where trying to install Catalina, there have been reports of problems with the updater. So its important to first upgrade in order through the releases and then go to Catalina. If that fails visit an Apple Store so they can fix it.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for your detailed reply.
FYI: I had to get an "original" Apple SSD to manage the update. Of course in the Apple store they did not want to do this (because my problem was caused by an inoffical SSD) :-) but I found a nice Apple specialist who replaced the SSD, did the updates and then installed my SSD again.
完成的
添加一条评论
添加你的答案
Pascal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 438
