跳转到主内容
型号:A1419/ 2012/2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 专业版
323 个问题 查看全部
iMac Power Supply problem?
Hello
Please i someone can help me
My imac power off while i working .now i press power button and nothing happen .no fan sound no hdd .nothing at all
I open it and when i conect it to outlett power .first let come on. When try power on pressing the power button led 1 blinking 1 time but 2led did not up. .what can be this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Thank you i thik that was happen . i will order Power Supply a new one and a UPS for future proteccion
Thank!
完成的
添加一条评论
1个答案
已选择的解决方案
Here's a breakdown of the onboard diagnostic LED's:
LED 1 - Indicates that the trickle voltage from the power supply is detected by the main logic board. This LED will remain ON while the iMac is connected to the AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power is disconnected or the power supply is faulty.
LED 2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED 3 - Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
Sadly, this does indeed looks like a bad power supply! iMac Intel 27" (Late 2012-2020) Power Supply and here’s the guide to put it in iMac 因特尔 27" EMC 2546 电源更换
I would point out a power surge or lightning could have hit you. Make sure you have a good surge suppressor and all of the peripherals are likewise plugged into the same surge suppressor. If you suspect that was the cause you might want to get a UPS as best solution.
You might want to check your outlet ground and the breaker panels ground connection to the water pipe (copper) or grounding rod/s making sure the surfaces are not green with corrosion.
iMac Intel 27" (Late 2012-2020) Power Supply图片
产品
$99.99
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Orlando Luis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 92
总计 2,361
