跳转到主内容
The Samsung Galaxy A5 (2016), an Android Smartphones released by Samsung Electronics in 2016.
58 个问题 查看全部
Change screen failed, the screen is thicker than the original
Hi guys, i had try to change the screen of my phone that is original with a screen that i have buy from ebay. I have test the new screen and it’s ok, but when i try to mount the screen i have seen that it’s thicker than the original. There is someone thath can suggest me some solution ?
Thanks
Arturo
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There are a ton of these budget Samsung models. They may look very similar however parts for them differ slightly from model to model. You could have the wrong part. Could also be a low quality replacement since you got it from Ebay. I steer clear of these sites for parts since you never know what you are going to get.
这个答案有帮助吗?
得分 0
2条评论:
thanks for the reply, but I also bought the screen from Amazon with the same result, the screen is thicker. I think the problem is the type of screen because I have seen that there are two different types: TFT and OLED, in fact the first is thicker and less expensive than the second. I think you have a lot of experience, I have a question for you, when you need to replace a component of your smartphone that doesn't work, how do you look for this component?
完成的
Sorry about the late response. Most phones will have a model number on them. On most of the budget style Samsung's, this can be found on a sticker typically under the battery. I then go to me vendors with the part number and can get the correct parts that I need. As a general rule, I do not discuss who I get my parts from.
完成的
添加一条评论
添加你的答案
Arturo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 18
总计 315
