跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
What is this small golden connector, and why won’t it go back in?
Just underneath the battery connector, what is the golden connector, with a black pad on top, that just won’t go back in, circular in shape. No matter how hard I press it won’t go back in. What is it for, and could it be related to my phone not charging?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Do you have an image of the golden connector?
If it’s the one I’m thinking about then yes it is related to the iPhone not charging as it is part of the charging port. If it is by itself just hanging loose or completely broken off of the charging port then it will need to be replaced.
完成的
I think you might be talking about the antenna leads. Is it connected to a long, thin wire?
完成的
添加一条评论
2个答案
pretty sure you’re talking about the wifi antenna lead, if you dont plug it in your wifi wont work
(one i found on google - https://www.replacebase.co.uk/apple-ipho... )
这个答案有帮助吗?
得分 0
1条评论:
Yeah, I don’t know why, I put it it over the connector, screwed down the metal plate and everything seems to work fine
完成的
添加一条评论
If you try to force the connector on you could have inadvertently damaged the socket on the main board by bending it out of shape, in which case you will struggle to get the connector to locate.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Charlie While 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 70
