跳转到主内容
What is Material of small button?
My power button is lost, so i use small button ( to turn on my handphone). One day this small button is broken. so i just press it, not working without this small button. so i try using shred (or tiny sheet?) of small button and work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
im assuming you’re talking about the buttons with the black stuff on the back, if so this is carbon which conducts electricity, on a circuit board you would have two traces (copper bits) and joining them together would complete the circuit and turn your phone on, the carbon is normally suspended above by a silicone membrane which when you press it deforms allowing the carbon piece to complete the circuit, if this is the case (would need more specifics on what you’re working on) then you could steal a piece from an old calculator or something else that uses these buttons and it should work ok but honestly i think id just replace the button if i were you because you wouldn’t want to leave it in there or it would be like constantly holding the power button down
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zero 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 68
