跳转到主内容
Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
139 个问题 查看全部
I over loaded my washer and it overflowed and won’t get any power..
I stuffed a huge blanket in the washer and I guess it made the water overflow. There’s water on the floor but not that much. But the power is out on the unit completely. The washer and the dryer. I tried resetting the electricity breaker switches for the laundry room but still nothing. I don’t know what else to do…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi
What is the make and model number of the washer / dryer combo unit?
Did it trip the breakers or did you just reset them both (turn off / turn on)?
It may be that the water caused an electrical problem with the washer / dryer’s control board.
With the power totally disconnected from the washer, open up the washers control panel and check for any obvious damage to the control board e.g. burn marks, blown components etc.
If you spot any damage (or even if you don’t) and are not quite sure, take some close up pictures of the board and post back here.
Here’s how to do this.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
添加一条评论
Are these connected to a GFCI Outlet? These are the ones that have the two little buttons on the wall outlet. These are often installed in areas around water such as kitchens and bathrooms. These are designed to work like a breaker but at the outlet level. If you see two little buttons try and press the one that says reset.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jennifer de la rosa 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 5
总计 57
