跳转到主内容
Repair information and disassembly guides for shop vacuums and wet-dry vacuums.
17 个问题 查看全部
New vac lost suction makes noise but filter brand new and hose clear
It is one of those small, tall shop vacs (4 hp 4 gal) that has a 20 ft hose. It has worked great all summer. Acts like partly blocked but I installed brand new filter and made sure hose is completely clear. Maybe noise coming from motor, what would cause that? It’s a shop vac brand but not that model listed here. Brand new last spring.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Yeah there isn’t much to shop vacs. It’s the the hose, filter setup or motor. That’s pretty much it. Unplug the hose and see if you’re getting suction at the base. If not and you said the filter is good, then the motor (you said was noisy) is damaged. You might be able to open it up and check for something fouling up the motor. Since it isn’t that old I would write or email the vendor and complain of the failure and they may offer a replacement for minimal shipping or no charge. Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
Loss of filtration at some point is often at the root of this problem. What happens is dirt gets sucked up into the impeller chamber. It happened to me when the retainer cap fell off the bottom of the filter and the dirt was bypassing the filter, but it could happen with a poorly seated or damaged filter, too. On a ShopVac there is a coarse sponge-like filter inside this housing to catch any larger fragments and dirt before it gets sucked into the impellers. It isn’t a complicated repair, 15-30 minutes. Pull the lid off, invert it,
and remove the screws anchoring the lid to the vacuum unit and separate it.
Then there are a few more screws to remove from the dome that was under the water-stop ball and you have the chamber and filter exposed. Remove this filter and clean it.
It’s doubtful anything has bypassed this filter that could be throwing the radial balance of the impeller disk off, but if you think that is a problem you’d need to go further to expose it and probably run a wire or small brush into each opening to check. However, if the ‘sponge’ is intact that is very unlikely. Increased noise from the unit is usually related to the motor straining against the lack of airflow.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
T shank 将永远感激不已
浏览统计数据:
过去 24 小时: 16
过去 7 天: 150
过去 30 天: 713
总计 10,861
